Other Blowsion bilge switch-handle pole mount
USA
Blowsion handle pole switch for my bilge is shorting out. Can it be taken appart? Anyone try this?
OCD Solutions
Rentz, GA
It will depend on where the fault is. If it's in the switch itself then you are screwed, if it's anywhere else then you should be able to repair it or splice on new wires.
Sent from my SCH-I535 using Tapatalk 2
USA
yes, its in the switch itself. I guess, it's worth a try before I throw $70 down the drain. I will take it appart and try to seal with 5200 after cleaning it . We will see. Thanks.
