- Kennewick, WA
I pick up a set of tubbie destroyer's. I am trying to put them on but I think the blowsion instructions are f'ed up.
According to their instructions For the 2008 super jet you need to measure 41.5 inches from the back of the hull and mark a line. Then you slide your sponson up to that line and thats where the sponson should go. If I measure out the 41.5 inches there is no way the sponson will fit.
If I use the 2007 superjet measurement which is 37.5 it fits but I have a good sized gap between the bottom of the hull and the bottom of the sponson. I guess I could shave the lip of the sponson with my dremel so it fits up to the hull tight. Yayyyyy!!!!! More grinding on expensive parts!
What measurement has everyone else used?
