- Horsetooth reservoir, CO
Installed tubbies during a build on my 97 RN. Took it to the coast this weekend and one of the tubbies had partial separation from my hull. I used 5200 along with the stainless screws provided by blowsion. then I glassed the edges before paint. It's not coming completely off, but one screw actually backed out and you can slide a screw driver between the hull and tubbie (along the bottom). Should I pull it off and start over or just run some stainless bolts (flat head and counter sunk) through the hull? thanks for your suggestions.
