bluegtate
X-
- port hueneme ca
Here is my ski I have been working on for about 8 months. It is a 1996 Yamaha superjet with all the goodies.
Engine/Driveline/Electronics -
The motor is a 62t/61x JetWorks freeride port work and power tuned by the man himself
Wiseco 81.50 pistons
Hot Rods trued and welded crank
V force 2 carbon reeds
Riva reed spacer
Mukuni manifold
BlackJack 44's
PJS throttle wheel
My own mod to run stock FA's
JetWorks flow control valve
Factory B pipe with mod chamber bored out by jetworks
Cold fusion Kawasaki billet style coupler
Cold fusion billet O-ring flywheel cover
¼ girdle billet Cold fusion head 34cc domes
Monkey mounts
MSD enhancer
JSS coil
Lightened 62t flywheel
JetWorks battery
Blowsion internal fuel fill
Hull/Handling
Full interior re enforcement. 1 layer of knytex on sides, 2-3 in the nose. Sides covered in 1 layer of 5.5oz carbon
Frenched in Blowsion Tubbie I (surf/rec) side sponsons.
WaterDawg Diablo lowered hood and nose piece
WaterDawg REV foot holds
HighRoller front foot hold
Oxnard111 and my turf job
Xmetal finger throttle
Blowsion lowered pole bracket
Blowsion spring
Blowsion -1.75 turn plate
UMI -2 pole
UMI bearing system
UMI 0 degree bars
24/7 carbon chin pad
HighRoller composite ride plate D cut\
Pro-tec scoop intake grate
Wamiltons freestyle pump cone
Hooker 9-15
New OEM wear ring
Accessories/Necessities
Dual 500gph rule bilges
Start/stop mount bilge switch
ODI grips
ODI billet goodies
Black bilge outlets
Black bow and tail bushings
Front Tow loop
Limiting Rope
Stock hood latch with wamiltons hood straps
Blowsion hood hooks
Riva Billet gas cap
Riva reed spacer
Mukuni manifold
BlackJack 44's
PJS throttle wheel
Monkey mounts
MSD enhancer
JSS coil
JetWorks battery
Hull/Handling
Blowsion spring
UMI -2 pole
UMI bearing system
UMI 0 degree bars
Hooker 9-15
New OEM wear ring
ODI grips
ODI billet goodies
Black bilge outlets
Front Tow loop
Limiting Rope
Blowsion hood hooks
Riva Billet gas cap
