Custom/Hybrid bob hull reinforcing
Yes same place and I sanded everything down good before I did. Mine happened because I have a flat water layup and I took it in the surf...my bad
Cracks are in different places , am i supposed to put it in on my drive and not ride it and just look at in case it cracks ?!
ProSouth
Seriously, Don't be a dick.
kawasakis suck
Ouch, did you give DK A call? Sucks you're in the UK. Kinda hard to deal with these issues. My recommendation, would be to pull the engine, buy a little carbon and reinforce. Your hood lip, the sides, and the nose.
Yes I spoke to them they said stress cracks can occur on failed tricks ! I would to some extent agree but after all this is an aftermarket hull designed for tricks so surly it should be able to handle 7 rides in flat and small waves !? Do other hulls crack this quickly or am I just unlucky
ProSouth
kawasakis suck
Depends on how your landing man, barrel rolls are probably thd worst to fail at. Do you have a shock pad on the pole? Maybe the plod caused the crack on the hood lip.
Tyrant1919
Washington, DC
You'd cry if you saw my G3. Mine split in the same hood lip area. I have the crack of all cracks on the nose between bottom and top deck. A hole covered with duct tape right where the top bpipe header screw would be closest to the hull. I've broke all 4 motor mounts from a failed barrel roll. I'm not sure how hard you're hitting, but poops gonna break unless you're landing everything. Luckily I live close to the clinic and have been pleased with their after purchase support.
glass , seriously don't bother , its cracked everywhere , and ski clinic have done nothing ! mine will be ready for the bin by xmas
nw
Hmm thats discouraging. Guess ill look out for a backie or rickter. Wish bob would bring there quality up a bit.
i just bought mine. grante its carbon and has a crap ton of reinforcement but i guess ill stick to my 300sx for learning tricks so i dont destroy it
yes pay a little more get something that lasts and from ppl that won't fob u off , they lucky i live in europe is all i can say …pissed is a under statement !!!!
