Adjust your fuel pressure. I bet that is part of your issue. You'll probably end up with a 80 to 90 main jet in the return to get your fuel pressure to 1-2psi at idle and 4-5psi at wot. As stated earlier, it does sound a little rich to me on that 3rd trick. If it was lean, it would've most likely died. I had some strange fuel issues with my built 735 with dual 44s that had the returns drilled out. Went from a 70 to 85 jet in the return and it was night and day difference. Yours being a stroker and much larger bore will just amplify the issue. Too high of fuel pressure is similar to too low of popoff. It'll cause fuel to dribble past the venturis while riding that will cause random rich bogs that clear out after a few quick throttle blips. Lowering the fuel pressure cured the dribble.
