Midlake Crisis
- Bakersfield, CA
I have been trying everything to get rid of a top end bog that started out as an intermittent bog that only occurred after tricks, moved on to a consistent bog that would allow short "braps" but as soon as you held the throttle open it would bog. I changed eBoxes, changed carburetors, same thing.
By then I figured it must be the stator or a twisted crank. That is all I have left. . .
While testing in the shop the starter went completely out.
Won't even work when hooked directly to the battery.
Is there any possible connection anyone can see between the starter going out and the original bogging issue, or is it just an unhappy coincidence?
