bolts: teflon, loctite or nothn....?
x
hey all
i currently hav my engine out and about to put back everythn in.
1) which bolts are we supposed to put teflon paste on? blue loctite? nothin? (pipe, engine mounts, girdle head, ....)
2) quicksilver lubricant with teflon...wud dat work instead of teflon paste ( http://www.wholesalemarine.com/p/92-802859Q1/ )
or marine grease, since am guessin its to prevent salt deposits.
tkx
Rickster
Matakana Menace
hey all
2) cannot find teflon paste... can i put marine grease on instead? found some quicksilver lubricant with teflon...wud dat work?
tkx
Personally, I use grease (anti-seize) on everything except reed/cage screws, inside the electrical box and inside the front stator cover.
If it can get wet, then it will corrode eventually if ridden in Saltwater.
Tanman
Jus' keep er' pinned
Ketchikan Alaska
I just used never-seize the silver stuff on all my superjet hardware. I have used this grease called superlube and it works good on areas that aren't exposed to frequent water. It will wash out over time from what i've been told. but just my 2 cents. I would like to know the ultimate thing....
227
Its all about the surf!
Oceanside, CA
Dude coat EVERY bolt on your ski with ANTI SEIZE. Its not a lubricant and its not a locktight, it just prevents corrosion buildup on your bolts. The stuff is AMAZING. I ride 100% salt water and have NEVER had an issue removing bolts that have been previously coated with this stuff, even bolts that were coated more than 2 years previously.
WaveDemon
Not Dead - Notable Member
Hell, Florida
blue locktite on everything except x-metal pole bolt. I'm cursed with bolts that loosen after I tighten them.
thread sealant on the long bolt shafts that yamaha uses is a nice touch too (I don't do it but I appreciate it when other do)
dfw
Loctite works well on fasteners that never need re-torquing. Anti-seize doesn't seal water out but acts as an anode between steel and aluminum. It works but is like treating a patient after you have made him sick. BTW it must be zinc not copper anti-seize. My personal favorite is teflon thread sealant, it has anti-seize properties and keeps water out. Waterproof marine grease also does a good job. Whatever you use make sure the bolt head is sealed, if water never gets in it cannot corrode. Also be careful when torquing with lubed bolts, use the lower value listed or they will be effectively be over-torqued
If you can find the miltary grade anti seize its black and not silver i think perma tech makes it still - i dont think the silver stuff is salt water rated
The other thing i like to use is 1211 or the stuff u use on gas lines - pipe dope on those long pump bolts
Roo
it's all good
You put RED loctite on everything?
Screw that.
thats crazy!
we use nothing but red grease fortified with antiseize...get it at the auto parts store
i have had to many things come loose / fall off, etc due to bolts/nuts coming loose... i torque down everything with a torque wrench and set it to spec as best as possible (with the #'s i have found on the forums / service manual(s)).
i have never had a problem with removing, cleaning and reapplying new loctite if something needs to be taken apart / reassembled.
OCD Solutions
Rentz, GA
I bought a tube of that grease last night at Advance Auto for under $5. Every single bolt on my X-Scream engine is coated in this stuff so i figured I'd use it on my new build.
lucas oil products, "Red and Tacky #2"
http://www.lucasoil.com/products/display_products.sd?iid=46&catid=14&loc=show
Red 'N' Tacky Grease
Lucas Red 'N' Tack Grease is a smooth, tacky, red lithium 12-OH grease fortified with rust and oxidation inhibitors. It has good water resistance and washout properties. It has excellent mechanical stability and storage life. It is able to withstand heavy loads for extended periods of time. It can be used in many agricultural, automotive, and industrial applications. Lucas Red 'N' Tacky Grease is fortified with a high degree of extreme pressure additives that give it a TRUE Timken load much higher than other greases of this type. Its especially good for sliding surfaces and open gears.
Key Benefits
•Rust and oxidation inhibitors
•Water resistant
•Excellent mechanical stability
•Long storage life
•Agricultural, automotive, and industrial applications
Packaging
•#10005-10 - 14.5 oz. cartridge (10x1) - 11 lbs
•#10005-30 - 14.5 oz. cartridge (30x1) - 34 lbs
•#10005-60 - 14.5 oz. cartridge (60x1) - 68 lbs
•#10027 - 35 lb Pail (1x1)
•#10028 - 120 lb Keg (1x1)
•#10029 - 400 lb Drum (1x1)
