Bond rail glue
Sanoman
AbouttoKrash
NE Tenn
Bond the two decks lol
OH CRAP! l need more coffee! Thanks for asking @jonolove! Forget what l said!.When l first looked at it l had turf on my mind (drank way toooo much last nite!)
Find a two part epoxy that will give a window of about 45 minutes to set up.And one that will work with glass and composites
BrightE's
Paul
Seattle, WA
Any good 2 part Epoxy, and 1/2" shard glass, thicken with cabosil. Prep the surfaces with 36 grit sandpaper, you want every inch scuffed HARD. Clean with acetone to remove oils before bonding. Clean before sanding with acetone to prevent pushing oils into the grain when sanding.
Good luck.
Sent from my RS988 using Tapatalk
