- Jacksonville,FL
i always wondered about cutting the rear bond line. seems to me that it would allow you to get the nose up faster at low speeds and have little effect of cornering. if anything it would get rid of that corner pocket that just grabs water in a hard turn and reduce drag.
true on the rear, but i cut the side rear farther forward, i should get a pic from the side rear to show it better, its not bad while cornering do to the angle of the rail. just picture the rail at 45 while riding straight and when you go to corner the rail is close to 90 so it catches more than it would with a 90 bond rail?(atleast thats my theory) but since i cut some of the rear out it slides just a bit more.
