Freestyle BPipe figment
Do guys have trouble fitting the BPipe manifold with power valve motors?
It looks like it may not clear the valves. Anyone have pics or comment on using a BPipe with a PV motor?
Thanks!
Blue
Judging your cheapness
St Cloud Florida
Only pic i could find but there very close. @JetManiac has small bolts for center of bpipe makes them easier to access. You may need to clearance the mani to help it clear.
Sent from my SM-G781U using Tapatalk
It is possible to insert a spacer between manifold and header pipe, using 2 x gaskets, care needs to be taken around header pipe and it touching the manifold lower down to prevent stress - also material may need to be removed from inner side of header pipe, lots of work but can be done - I will try find you some pics
