BruceSki
Formerly Motoman25
- Long Island
http://pwctoday.com/f72/bruces-2003-superjet-build-143342.html
here is what i did last year.
now i changed a few things around.
Before daytona i got a WDK diablo hood kit. I also switched from a TBM pump cone and 12/17 skat mag prop to a stock prop from an 08 SJ.
I also yanked off the surfjetlouie tubbies and got a set of #.0 tubbies.
Since then i bought some more go fast parts:
msd enhancer, riva intake mani and 44's, boyesen reed petals, prok flame arrestors.
last summer i stuck a ring on the front cylinder. I honed it and put some used pistons in to get me through the season.
Now i got some .025 over pro-x pistons, and its going to be ported as well.
tonight i put some straight bars on my stock turnplate. should get the pole/steering setup a bit shorter. UMI bars measure 25 1/2 inches. I cut my straight bars to 24 inches.... hope I like them 1 1/2 less wide.
EDIT: straight bars at 24 inches would not work, the throttle would hit the pole before the steering went to full lock. I just cut another set of bars at around 27 inches, im going to see how I like them and cut them down more if i have to.
