Freestyle Bun hull build (maxx hull)
denmark
Ha ha funny yes its my first, you get soo dame proude. More ski related Got a big box from jetmaniac today, with the rest off my parts for the ski. And my engine builder got the 10 mm crank from ADR,hee ordered in pieces soo hee Can balance it out For less engine vibration. Was a littel bumede when i got a PM from zack att PHP that ther cranks is 1100 US and the ADR is 800. Plus zacks shipping was 56 US too Denmark, hee tells me its 2 lbs less weight then a stock crank. And the ADR is heavyer then a stock, will get one from him next time for sure.
denmark
Got home from the hospital today a got a Big box off godies from jetmaniac.
Just as a reminder for international buyers, it took usps from december 10 till januar 9 too get it too me. The holidays makes everything go slow
denmark
Build is moving on ebox is finish with new battery wires and ground wire.
Used scotch coat on all wires nice product used in the offshore industri.
Also put the pump together and fittede it too the hull, it need 2 shims in front off the pump and hade too drill the holdes in the exit nozzel. After that it fit pretty nice, shaft alignedment tool from cold fusion is Dam nice too have thanks Christian83
denmark
Moving on borrow a dasa engine from a buddy too test ignition, and aligne midshaft motor mounts here is the bench test setup.
Spark seemes better with the new yamazaki coil, also put in pumpshoe and intake grate bit off grinding too make it fit.
Foxboro
Foxboro
Try to move back wP2040376.JPG aterbox
