Calling all total loss gurus, electricians, and electrical engineers
McDog
Other Administrator
Staff member
South Florida
Update: Hooked it up and cranked the ski this weekend. No current between negative battery post and anywhere else I put multimeter except a tiny 17 milliamps from pfp chamber for some reason. I figure maybe because saltwater in water jacket? It was touching nothing. I left the battery hooked up all day and periodically checked it with no problems. I guess it was solenoid that I replaced or maybe extra ground wire from ignition to battery or a bad cable because I replaced them all and took out the extra ground wire to battery.
McDog,
I am an electrical contractor. I mainly deal with AC circuits but has a decent grasp on DC theory. I am clueless on TL (just saying). However, in your original post it seems like you may be paralleling the ground back to the battery. Weird, weird things happen when you parallel a ground from multiple points back to the source. In AC circuits, it is acutally against Code requirements to do such a thing.
I would highly recommend only 1 path from the battery to a common point. Example would be from the battery to the engine block, from the block to a terminal block (or maybe the ebox) where you would bond multiple ground wires. Ultimately, you only want a single return path back to the ground for both high and low current circuits.
Hope that makes sense and helps. I know you already did this but figured I would throw it out there for some insight and for anyone else that may read through the thread.
McDog
Other Administrator
Staff member
South Florida
McDog,
Thanks brother. That definitely explains things.
Quinc
Buy a Superjet
California
McDog,
ATP also recommends this in there TS2 instructions.
