Can Someone Double Check My Bendix Assy?
Putting my motor back together, and I've discovered many wrong things along the way, so I'm double checking everything. Anyways, I don't know if I have this bendix assy correct? seems like I'm maybe missing at least a thrust washer on the flywheel cover end?
This pic shows how I was planning to put it together...Flywheel cover, Bendix assy, washer, case. Good?
Thanks in advance!
Alright, that's what I thought. Thank you. Ski didn't have them when I took it apart...was starting fine lol. Looks like blowsion has the spring. Does anyone know the approx washer dims so I can just pick some up locally? Otherwise I'll just match them to the spring and bushing sizes.
Btw, this is the pic from the manual, hence my confusion lol.
Im sure the spring is supposed to be there to prevent it wiggling around causing extra wear on the teeth
Jetmaniac would have them probably cheaper and could get them faster then Blowsion and he would probably get the dimensions for you.
Sent from my SM-F916U using Tapatalk
