- California Central Coast
Are you saying there is something wrong with having lightly oiled bores on a new topend prior to startup? As in, something bad will happen?
Why?
Not saying you can't lubricate the cylinder walls but the chances of your rings not seating properly are a lot higher when the cylinder walls are lubricated prior to start up. Just did a top end on a 09 sj that was freshly done by someone else took it apart and it had lots of blow by from the rings no seating properly.
Only a recommendation. Everyone does stuff different. This is the way I roll and its never failed me. This info was from my machine shop guy that has tons of two stroke experience. I have pictures of the pistons ill try to post.
