tiplickhahaha
Hummmmmmmmm
- Indianapolis, IN
anyone care to explain compression ratio?
(Cylinder volume + Combustion chamber volume) / (Combustion Chamber Volume)
Cylinder Volume = Pi*((bore/2)^2)*stroke
Combustion Chamber Volume = Head volume + Head Gasket Volume + Deck to piston volume + Crown Volume. Crown volume can be plus or minus depending on if it's a dished piston or a domed piston. If it's dished, you add the volume into the total equation. If the piston is domed, you subtract the total volume.
Head volume = #cc's (33, 35, etc)
Deck to piston volume = Pi*((bore/2)^2)*(Deck Height - (stroke+centerline of piston pin to top of piston (only count major flat portion)))
Head gasket volume = Pi*((head gasket diameter (measure it!)/2)^2)*Thickness of gasket
Watch your units!!
Doug
Watch your units!!
Doug
1:43'20"
103mi 1760'
