Hi!
I'm fairly new in jetski world, so I have some basic questions for you that know better.
I recently bought Kawasaki 750sx ( about 1995-1996) with following mods to the motor:
Dual 40mm keihins, stock flame arrestors without those rubber pipes, R&D exhaust manifold,
Factory pipe, timing advance plate, some aftermarket ignition system, slightly lightened flywheel, lowered head.
There is fairly new pistons in, like 20 hours been there. Compression test says 150psi.
I have been struggling with carb settings for a while now so I would like to get your opinion on these.
Main jet: 150 adjusting screw 1/2 turn out
Pilot jet: 88 adjusting screw 7/8 turn out
Pop-off: 25 psi
I haven't yet changed the jets my self, these are the jets that previous owner had in.
I've only adjusted the screws and lowered the pop-off , from 35psi.
Does anyone see a problem on these?
The low end power is totally missing, on the high end it works decently.
But because of my driving is mostly freestyle, the low end really needs some improvement.
I have a feeling that on low rpms the jet runs really rich, and then it takes some time to get it running again.
Like after when I ride on low rpms for a moment, I have to drive on full throttle for 15s before it gains the full power.
Also I have a problem that the pipe is running really cold.
I replaced all the adjusting screws on the pipe, because they were stuck.
Now my screws have a flat end. Does the original have a sharp end?
I'm just thinking that when I open the bottom screw 1/2 turn, the whole hole is totally open.
Now I'm running top and middle screw closed, and bottom 1/4 turn open... And the pipe is still cold.
Should I just close the bottom more than 1/4?
Factory pipe just recommends that not to close all 3 screws, I'm pretty close to that.
Hopefully you can help me with these.. Thanks!
Pop-off: 25 psi
