Carb settings help plz
Trying to find stock carb settings, or a setup that would work best for....
95 kawasaki sxi keihin dual carb.
Stock impeller.
TDR waterbox.
Blowsion tornado air filters.
I know stock is 75 low and 115 high. But what are the stock turns on the high and low screws?
I have 80,85,90. And 125,135 jets i can put in as well if needs be.
Hey Ryan, what exhaust are you running now? Also might want want to bring this over to pwctoday.com. WAY MORE Kawi guys on there and you would get better help faster.
Hey bandit. I decided to ditch the coffman. I couldnt get the thing to run fast. No topend and ran like a dog. I was able to get rid of it dying with WOT by moving to a 90 low jet. But it was soooooooo dang loud . Past emberacing. So i went back to stock exhaust, tdr waterbox, and tornado blowsion air filters. Just trying to find what to set my carbs to now. They are CDK2.
waking up this thread a bit. wasnt able to get it running optimally so i ended up buy a new carb.
now realising i should have done more research before i bought this one.
http://www.ebay.com/itm/262865033793
Im noticing it has 3 internal jets, and it was for an XI not an SXI 750. They look practically identical. anyone know if ill be okay? they took it out of a working XI, so i was hoping i wouldnt have to adjust any of the settings. but im guessing i will?
Do some searches on PWC today about tuning the 3 jet carbs. Good thing is they are supposed to be better. Otherwise shoot a message to WMAZZ on pwctoday. He knows all about those and should be able to help you out.
