Worth mentioning not sure if you tried check valves yet.
Yeah, thats been an issue in past, but not with these carbs as of yet. However, I went out at lunch and dropped the popoff (didnt have 2 80g springs that would pop the same, so put in 65g springs) so i am popping at 18 down from 26psi, big jump. When revving now, I DO have some dribble in rear carb. A problem for another day LOL. It idles way smoother but I cannot get the low speed to increase the idle
that sounds like your main jet is rich to me. If you hammer the throttle to half throttle how does it feel vs full throttle?
When doing the standard jetting test. 1/4 throttle, let off, hammer. No issues and Full Throttle, let off, Hammer it, NO ISSUES.
The issue ONLY shows when at low throttle or blipping throttle, letting completely off (dropping into s setup wake) and then hammering throttle.
Update:
The gas tank showed yesterday afternoon so I decided to install the Bun pipe rather than go test the new popoff setting yesterday.
So this evening I will be testing the Bun and new popoff combo (I know, one change at a time), but I couldn't resist , I think the Bun will be better suited for this 701 setup than the PFP as it gives a little more on bottom end and water can be adjusted via jets to tune throughout.
I was on the verge of adding water injection to the PFP before finding a Bun reasonably priced.
