This is the piece. There are actually two sections. Its an air intake coming from the airbox to the front of the ATV. I would think some one that has worked with CF could fix this up fairly easily. It has to be similar to fiberglass right?
go to your local composites supply shop and bring it in. easy repair you can do yourself for just a few dollars. Likely will be someone in the shop that oculd do the repair for you if you really dont want to mess with it.
