- pine beach, nj
I am not sure what's up with my carbs, but if i ride for 2-3 hours the carbs get really fouled and i have to replace them. I am having an issue that i am not sure how to correct. The ski pulls unbelievable however there is on spot in the power curve that it hesitates. You can ride and keep popping the throttle and it responds awesome. The problem occurs if you go to hit a wake, release the throttle to roll into it and then crack it wide open. There is a hesitation there where it take 1-2 seconds for the ski to react. I submarined through a few trailing waves because of this. The carbs getting fouled makes me think it is running too rich, but I am not sure if i need to lean out the highs or lows.
