Carburetor Help
Australia
Just checking are all Carburetors the same from JS750C1-C5 as I thought my 2001 C4 version had 40mm Mikuni's I see the same Mikuni rebuild kit is for 1998-2002
on the manual I got its October 1997 Published it says the sxi pro has 38mm Mikuni's ?
I have attached the PDF of the carby my 97 manual regards Robert
  • 750SXi Pro Carby.pdf
Australia
Ok thanks for the reply so thats when the brands of carby change... What about the size do they differ from years? Or are all mikunis 38mm ???
Sent from my GT-I9210T using Tapatalk
Australia
General Spec's
Engine Type 2-stroke, 2-cylinder, Reed valve, Water cooled
Displacement 743 cc
Bore x Stroke 80.0 x 74.0 mm
Compression Ratio 7.0:1
Ignition System Magneto CDI (Digital)
Lubrication System Pre-mix (60:1)
Carburetor Mikuni 40mm Diaphragm Type X 2
FRom: http://www.kawasaki.com/DefaultFrame.aspx?strContentURL=/Site/VIVehicleInformation/VIservicespecs.asp?intCatalogID=2&CatalogTypeID=2&ProductTypeID=44&ModelMarketingID=200&ModelCode=JS750C5&ModelYear=2002&SHOWVEHTABS=1
Nice thanks for the reply magy I didn't know you could look on there site and find specs of old water craft :)
Magyar68
Really!!!
Lewisville
So those were for a 2002, you can not search 1997. In 97 you would have Bought a 96 or a 98 Sxi Pro. You may need to use your ViIN on the Kawasaki site to figure out which you have.
