Case Porting & Epoxy - Opinions? (With Pics)
usa
this all plays a role in how much upper case work you do when adding bigger ports in aftermarket cylinders
also bore and stroke combinations all effect the primary compression ratio
Thank you sir, now what about sealing the cases on reassembly? Do you have any high quality sealant you guys would recommend? I was thinking something like 3 Bond such as Yamabond or the like. Anything more preferred?
With regards to the intake tract and putting the little scallops into the top side, is there a rule of thumb mathematically speaking for sizes, percentages or direct equivalents? What I mean by this is say just for ease of numbers, we had a bore of 100mm, the exhaust port is 50mm and we open that up to 68% of the bore (68mm). If you were to calculate the 18mm oversize it works to about a 32% larger port window. Would you then use that 32% as the rule for for diameter on the upper scallops? To further explain that thought, I mean would you make them 18mm in diameter or is there no real rhyme or reason for dedicating a size.
