Hi all! Now comes the time of year that I don't ride so all I can do is think about riding, and talk about riding. Well, I am fairly confident it was never a cavitation or "slipping" issue. Here is how I know. I was able to get a significant amount of low end pull by improving my motor's low end power. Yes I know, that's how it works! But if it was a problem with the pump pulling air, or cavitating, I think that an increase in engine power would not translate to better pop out of the water; it would just create more air bubbles.
The interesting thing is HOW I was able to get more bottom end. I was out on the river one day and noticed that I had some crazy low end pull that I had never felt from my ski before. This ofcourse made for a fun day of beginner flat water! Sometime later in the day I noticed that there was only a tiny stream coming from my bypass. I stopped and looked at the orifice, and noticed a little vegetation blocking the exit. So, I pulled that out and sure enough there was a nice normal stream.... But wait, WHERE DID MY POWER GO!? Was it resulting from my blocked bypass!? So the next day I made a restrictor at work (I think the hole was somewhere around 80 thou). When I tried it in my ski, yup there was my bottom end pull again!
So, does this mean that more water to my water box results in better low end power? It sort of makes sense. More back pressure. But I have a Factory B Pipe with the top screw opened up. I thought that was supposed to maximize water flow for low end? Any thoughts?
