Cavitation question Kawi 750SS 2-Seater
SXIPro
JM781 Big Bore
Is there anything besides a worn impeller/wear ring that causes cavitation? Just replaced a pump on a Kawi 750SS 2 seater because it cavitated like crazy. Put in different pump, same result if not worse. UGGGHHHHHHHHHHHHHHHHHHHH thanks
Myself
manic mechanic
Twin Lakes AR
Common issue on those is the plastic pump shoe. They will break right where it meets the pump. Or crack off to one side. Sometimes they are completely loose! Get it off the ski, fill the voids in with foam except 1/4". Then top it with epoxy resin and shape it. I've never had any return issues fixing them in that fashion.
Myself
manic mechanic
Twin Lakes AR
You can see the common break in these pics,
I agree on the compressed trim seal , I have had to back them up with sealant before to get them to seal.
