Chan hull ride plate questions.
How do I get this to spin better. Off a wake best I can ever do is a 270.. I have an original thrust trim that prob Hurts me a bit. Pro tec long nozzle, and a plate that is flush at the chines and bumps out 3 inches under the pump.
What are the fidgety spinners running ?
Sent from my SAMSUNG-SM-G890A using Tapatalk
Get a shorter nozzle for starters. When going for a 360 instead of doing a flat spin try and burry the nose when leaving your wake. That will give you a little more off axis roll than a flat spin but you'll pull more than 270*
Awesome thanks for the advice. A 155 pump should be showing up soon with a different trim setup hope that helps
