- 3 stacks and a rock, California
Has anyone ever thought about installing a dye pack inside their de-foamed skis as a cheap mod to assist in finding it if it goes down????? My idea would be to install a dye pack inside a small container with holes drilled in it stuck in an area of the hull that doesn't normally see water. dye packs run about 20 dollars and work REALLY WELL. you can also get septic system dye tablets for less then that and they would work really good too (the river in Boston uses septic tablets to dye the river every year for st patricks day.)
this would give people at least a few minutes to locate where its at and drop a marker on it.
I am going to get a few different types of dye material to experiment around with the idea and drop a few containers in calm/rough water to see how it works.
