- Oceanside, CA
#1 the ones he has on his ski are drilled out and lighter than an old umi kawi style coupler..is it going to make a huge difference??..no but it will make somewhat of a differnece
#2 if you ride in the surf hard you will break the stock ones..they are cast junk
#3 the advantage of the billit front cover is that it uses an oring so if you need to remove it you do not have to purchase 20$ gasket each time
hope that cleared it up for you
:lightning: :headbang::burnout:
