OK boys it's been a while since I've been active..... started a circus build ,stopped, started, then stopped again etc. I have summoned the build gods but apparently did not make the proper sacrifice..... can't understand went wrong...... O. .... wait a minute I think I've figured out what went wrong..... IT'S A F@#@##$$$$#@$$/^&% #$@÷% £#-@'$$$ JET SKI !
Here's the rub (no pun intended)
With perfect alignment the front of my motor is about 2.5 mm from touching the hull. The pump receiver could go up about a 1/16. This would move the entire drive train up
Curious what other circus builders are coming up with. I installed the intake system. Wow! Did I miss it by a whopping 1/16.....
