Coffman Raider pipe in a sj?
Has anyone tried to use this Coffman pipe on a Superjet? I was told it is off a 701 Raider and that it should fit on my sn. It's hard for me to tell from the pics but I'm thinking maybe the outlet isn't going to be lined up right. If it will fit with a little hose trickery I'll try it out but I'm not interested doing any cutting on it. Thanks
WAB
salty nuts
coastal GA
I think you'll have to cut the stinger end off of it and turn it so it would be facing the front of the ski like all other SJ pipes. Otherwise, it would be taking a 90deg turn right into the side of the gas tank or maybe in front of it if you're lucky. I don't think you have any room in that area to get creative with hoses to make it work like that....
It would have to be a SUPER deal to make it worth the trouble to 'make it work'
gorilla
There's Always A Light At The End Of The Tunnel !!
Lost Wages NV
that pipe should have a coffmans exhaust manifold, not a stock oem yamaha ehaust manifold ???
maybe that's a good cheaper setup that i have ever seen before ???
i got the fx1 - sj cheater pipe setup to work fairly well !!!
good luck
gorilla
chrisdoc0608
insulting
rocky mount, nc
save your money for a sj pipe... or do like gorilla and use the 650sx pipe, you could prob get one for free from someone then just buy a manifold. It will be better than stock.
