Great old thread with some good info. I recently got a Sizzler and put it on my 650 wave jammer. Labor Day weekend we data logged the heck out of the ski, 48.5mph at 7060-7080 rpm. I have a ball valve cutting the water line to the stinger down to half, as well as a flow control valve. Based on feedback here I am definitely going to try cutting the water down more to the stinger and possibly head pipe. This pipe has one ring cut which supposedly adds proportionately more rpm vs low end lost. Apparently a popular racers mod from back in the day.
I used to have a cheater pipe set up on the same ski. Previous max was 47.8 under perfect conditions. My best data logged run was 44.6 and 6600 rpm. For those interested how they compare, the cheater pipe was a good upgrade from the stock muffler exhaust, but the Coffmans is a much beefier, 5" dia big pipe. It hit much harder than the cheater pipe, and over a much more discernible rpm range. The power hits like a light switch, which I really like. The cheater pipe is a good baby pipe. The Coffmans is much closer to what a FP can do. I can't tell exactly because I haven't been on a ski which has run both. This is just based on feel being on other yamahas with FPs.
Anyone know what rpm these pipes make peak power at? I'm right at my 701 limiter now, which I'm sure is way above what they were designed for on 650s or even 701s.
