wydopen
onthepipe
- Goleta the Goodland
So I’m having a weird issue that isn’t really an issue since it runs fine on the water. Just wondering if anyone else has had this happen because I haven’t. Ski runs fine in the water no issues. But when I rev it up out of the water to clear out the waterbox it breaks up/misfires at high rpm. I’ve narrowed it down to what I believe is the jss coil. I have redone the ends but I soldered new ones on so should be good as new. Really doesn’t make any sense. Usually when it’s a spark problem it runs fine out of the water but shows up under a load. Anyone had that happen before?
