A couple days ago I got a rock jammed in my pump. I tried to start it several times not knowing there was a rock jamming it up. I ended up towing it back to the launch. When I got it home I pulled the rock out of the pump, however when I tried to start it, it would hardly turn and the coil packs started smoking. So I pulled the plugs and turned it over and found my motor was loaded with water which explains it not being able to turn over. So I pulled the spark aresters, flipped it upside-down and cycled it for a couple minutes to get all the water out, making sure to turn it over until every drop was out. Once all the water was out I flipped it over and tried to turn it over with the plugs in, same thing, coil packs started smoking, take the plugs out and it turns over just fine. I have since tried a different starter and also flipped it upside-down with the plugs out for an extended time to drain any possible water still in the motor with no luck, still having the same problem. The ski is set up with a Yamaha based Dasa 950 and an MSD total loss ignition. Any help would be appreciated. Thanks!
