When fueling, can't you tell by the sound when it's nearly full?
Can you use 2x brass 90' fittings (one top and one bottom of tank) and some clear pipe to create a gauge (like a kettle) up the side of the tank?
Jim
ive seen it on a few chopper fuel tanks. just use rubber o-rings safe for fuel. made out of the same type of rubber that your fuel lines are. i feel that they would be hard to install... but if you could, worth it!I'd say that would be too susceptible to leaking.
I said screw it and bought the black one. Once I receive it I will report back. I dont mind being the guinea pig, lol
