Cold fusion risers
hey,
I bought some cold fusion riser bars to go with the pro steering system. All looks nice till I go to bolt OEM start/stop on and the bar is too fat. Same with trim and throttle levers.
Anyone run theses bars?
Ok slightly different tack, I'll buy RRP risers to finish this one off with the levers I already have.
Is there trim and throttle levers that will fit the cold fusion risers without having grind them out?
I was wondering that, do you know if Cold Fusion make throttle and trim levers that bolt up to their fat bars? I also heard that cold fusion = Blowsion risers, anyone know if this is true and had the same issue?
eastcoastjumper
James
Long Island
I had the same problem with my rrp riser bars. They make those bar end extenders. I was going to buy those to get my width back So i didnt have to ruin my start stop switch. If you take off too much the thing spins
