300gsm = 8.85oz 200gsm = 5.90oz .
Had to look it up, only use oz in the US.
That is some pretty light material. A harness weave s-2 glass would be alot stronger, I like 8 harness, they make 4,6,8. I personally like working with 475-675 gsm for easy layup.
I would shoot for atleast 1800gsm+ on the bottom. No one has built a ski like a boat in recent times, so not totally sure on layup. Full fiberglass a/m hulls use a final layup ranging from 3400-6800gsm threw out the hull.
Don't use chopped, it's weak, heavy and epoxy doesnt break down the binding glue, like hink said.
You would want to wet lay vac bag, if you did any of that, it is the cheapest type to get into. Infusion and pre-preg is faster, but you need a gaint oven for pre-preg and infusion cost alot more to get setup.
