- Twin Mountain, NH
For Sale: Complete NEW MSD/ Zeel MS-01 Total Loss System. Completely wired and built system. $2300 shipped in the USA. Comes with the following:
New MSD Lightweight Flywheel
New MSD trigger plate
New pitch hall mounts and hall sensors
New case plug
New MSD tower coils
New Seadoo start relay
New MSD Plug wire set with crimp die
2 New fuse assemblies with fuses (10a for start and 3a for zeel)
New Zeeltronic MS-01 ignition
New programming cord
New WBW mounting plate
New ground strap for system ground to battery
New trigger mounting bolts
New OEM woodruff key
System wired with tinned marine wire, OEM connectors and 1 genuine Amphenol connector. Comes with documentation and support from WBW and LPW. System requires ground wire from system ground stud to your battery(supplied). This system is ready to go. Fully wired and all the small bits and pieces put together for you. You will have to install, set your timing and trim the plug wire length (we can do it for you if you give us specs). Summer is coming. Be the first to grab this one. They will be built on a case by case basis and limited supply throughout the summer.
New case plug
New MSD tower coils
