I've done some searches on the x and it seems like people talk about it but haven't done it, or posted their results. I found a fuel resistant epoxy that looks interesting: http://m.ebay.com/itm/310412309596?_trksid=p2141725.m3641.l6368
I plan on making a large fiberglass tank for when I go to certain Freerides and ride spots, and I enjoy glass work and think it should be fun. My plan is to glue some EPS together and shape it as needed, and use it as a sacrificial mold(melt it out with acetone or such). If the resin is truly fuel resistant, you could just glass over the foam right away. But.. I was thinking. There are some chemical resistant sealants out there too. You could paint it on, let it dry, and then lay glass over that. You wouldn't need a special resin then.
Thoughts?
Thoughts?
