701 stock bore, girdled ada head. Rear Carb plugged high speed jet lead to rear piston failure. Rebuild both carbs. Cleaned crank, put engine back together with new rear piston. Now I see it was very stupid to not replace front piston as my compression is 150 front and 182 rear. Ski idles perfect and runs like new at all throttle positions. My question is what damage am I doing if I run it this way? Crank? Only a few weeks of riding here in south Puget sound and wondering if I can run another dozen hours and then replace front piston as fall project? Thanks for help. Tod
