My new top-end is puzzling me somewhat.
It is a ported 61X big bore @ 84mm. I do not have the porting specs, but it certainly didn't look race-ported to me (but I didn't measure)
The bore is fresh.
I am using Wiseco pistons with 6 thou clearance and an ADA girdled head with 84mm 35cc domes, and B-pipe.
I am at 700ft elevation. I get 125 psi (maybe 130) cranking compression, even in both holes. Starter is just about new, spins the engine just fine.
The gauge, while cheap, works fine. For reference, I tested a stock 650SJ and get 150psi in both holes on that.
According to ADA charts, 35cc domes would yield approx 200psi on a stock 64x cylinder. So I am little off.:no:
I pulled the head after measuring the first time, because it seemed so low. The rings are good (brand-new) and so is the bore.
So my guess is that the porting is causing the low compression due to higher ports.
Now - the motor has very nice power. I really have no complaints, not even in the bottom end department. But, that could be because I don't know any better. The motor is new, so I don't know what it could be like with more compression.
I understand that cranking compression is not the only measure of compression.
To the builders: A cranking ratio would be more useful, right?
How is that calculated? I assume it's (volume above ports)/(dome volume)
Is that right?
What ratio am I shooting for to stay within premium pump gas range?
I run a stock ignition, advanced a couple degrees, dual 48 Full Spectrums with Dual Stage reeds in stock cages.
I do WOT runs.
I don't want to just slap smaller domes in there without fully understanding the consequences.
33cc domes seem to give me an additional 15psi, bringing me to 140.
Or 31cc domes, getting me to 160
The bore is fresh.
Is that right?
I do WOT runs.
