Super Jet Compression test
just did a compression test on my 05 SXR and my bro's 90 SN SJ these are my results
Compression testsKawi
#1=136psi
#2=163psi
Wet test
145psi
165psi
Yama
#1=170psi
#2=170psi
what is everyone else getting on there ski's? the kawi spec is 185psi
Comments, advice pls!
swannysxr
Lake orion, MI
I stand corrected, But my2005 SXR was not that high. no need for milling or aftermarket head then. Kawi mods, post your findings after you pull that head..
Idaho
Sxrs were sold new with compression ranging from 150 to 180 psi. Mine was new at 150. Most shops tested every new ski. They sold the lower comp ones and kept the higher comp ones for racing.
the Dome looks like its pitted, from factory... so im going to get a new head gasket and shave the head and see what numbers i can come up with
Proformance1
Liquid Insanity
New York Crew
For future ref, never look at the nnumbers. Only look at the difference in the numbers. if its 10% or more time to tear down. All gauges, IMO, read differently and are for comparison purposes only.
I was told stock SXR's should be at 170PSI or close to. comp gauges vary and so do the skis out the crate. 20 psi on your compression is no bueno homes! im almost in the same boat as you for mine as well mines at 147 even . top end time brother
so final results put the head on with a new gasket and tested it.... both cylinders 175psi now so i was luckily right on the head gasket being messed and found out that .035 off the stock head raises the compression 10psi
ya pretty happy about it! should be a lot better than 135psi in cyl 1 and 165psi in cyl 2, was thinking on putting it in today but i still have ice burgs floating in front of my place :17:
montreal
yeah,we got a big winter here in canada this year....i think we gonna start ridding only in june in quebec,lol!too much snow.
