surferdude345
X-H
- Blacksburg for school
Hey Pete there's a station in point b4 the bridge on the island side that carries i think 100 on the pump
At WF's, they are not going to take the steps that Supercross/AMA does after the initial test. If there was a trace, then you got DQ'd, because they could not determine if it was trace element or not. Granted, I have not heard much about it in the past 1-2 WF's as to being as much of an issue like it was in 05.
Pete, listen to Charles, or call your builder, they should have told you what your fuel requirements should have been from the get go.
That has happened in the past and may continue to, but because of past issues with this, more discretion been shown in the last couple of years. The problem with the test isn't that it's bogus, it's just pass/fail. A legal amount(trace) of lead allowed. The test used doesn't differentiate between trace and actual leaded fuel. There have been a couple of motorcross DQ's reversed by further testing. Testing for exact amount of lead is considerably more difficult and expensive. The easiest thing to do is just run the same thing in practice that you run in races. I think more often than not, people get caught out because they run AVgas or the cheapest leaded fuel they can find in practice to save money.
