Super Jet Cooler plug for hotter weather...any thoughts
SUPERJET-113
GASKETS FOR CHAMP BRAP!
Well it must be that all Superjets till 2004 use b8hs.. I have a couple OEM manuals for 6m6 and 61X that states b8hS.
Anyways, an 8 is what i would run in any year superjet personally..
tomski
X
LHC
Not that I really care but the OEM service manual calls for the b8 and the pipe has b7...time to move on.
FlightPlanDan
Don'tTrustAfartAfter50
Until you, or anyone else, can show me a performance difference...with math to prove it, I will advise OEM plugs no matter the weather.
Thank you for correcting me!
Folks seem to think a hot/cold plug means something it doesn't.
227
Its all about the surf!
Oceanside, CA
Most likely the manuels are contradicting the Mfgs sticker on the pipe. It doesn't matter- we're nit picking here. The original question was should the plugs be changed for a different heat range per the weather (seasons) and IMO the answer is no, it doesn't make any difference
i was trying to accomplish something like what's put in the radiator, stuff like Water Wetter. didn't realize spark plugs have no real relevance to physical engine temperature. guess the hot/cold nomenclature is very misleading, learned something new. headed out to the lake to tune my carbs so the 8's (HS) are going back in.
DangerBoy
Runs with scissors
Rincon Beach
The main Point I was making is NO oem superjet takes an "ES" 3/4 in reach plug
putting an es plug in an head designed for an HS length plug causes bad things to happen
he originally stated was using " B7ES" plugs
it is true that there are many instances of the Factory service manual not agree with what is actually on the ski as must be the case here
Db
Don 79 TA
Still Fat....
all i can say is i have always ran BRP7es plugs and no problems in both our skis
have done it in the super hot AZ temp area and have used in NY
i never get plug fouling despite the heavy mix ratio i use
as a note, i'm hardly ever WOT, mainly cause of the steep props i have used
Tyler Zane
Open Your Eyes
why would you get fouling from a plug with a higher heat range anyways... if anything you would foul less plugs with the 7's but that doesnt justify everyone switching to them.
The weather does not change the need for a different heat range spark plug. The water temp does to a certain degree. If a completely stock engine uses a 7 range plug then it would be logical that once we modify the engine with more compression and a pipe and maybe even porting you would need a colder plug. If your running in very cold water and are mostly on the lower rpms then there is no need to go to a colder plug.
