300/440/550 Cooling Help!!
I have a js 550 with a pjs exhaust, i know that the main cooling line goes into the bottow of the exhaust manifold. I have 2 fittings on my head pipe, i have a stinger fitting, and i have 2 fittings on the head, one on each side. Im confused on where to run all the lines...
do you have 2 fittings on the manifold where the water comes in. the head is set up for duel cooling. If you have 2 lines coming into the manifold, then the one coming off the front of the head will go to a pisser the one on the back of the head will go to the back side of the pipe, the from the front of the pipe to a tee fitting where you will split it to the stinger and another stinger. If you are not running duel cooling,.. then plug the fitting coming out of the head that goes directley to the pisser.
Jetpilot106
Kickin it old skool
this is how i got mine ran i have dual pissers but maybe it will help.I got the 2 lines from the pump going up to the exhaust manifold.then from there you can see.hope it helps
