- Corsica FRANCE
Hi,
I ve rebuild a motor for a friend of mine.
Setup is
Stock unported 61x cylinder prox piston .Gap as they tell
Type b limited
Decked stock head (minus 0.6 mm)
Dual cooling
2° timing mod
Stock dual 38 carb except the jet for the b pipe
and stock ecu
The ski just Keep overheating ( the temp sensor limit the ski after 2 or 3 straight line at wot )
Is this a common issue with this kind of setup ?Water is about 27 to 30° today
Do i need to just get rid of the sensor ?Or i need to search for another issue ?
Thanks for your input
Setup is
Type b limited
Dual cooling
2° timing mod
and stock ecu
