Cooling line question sn with 701
very interesting, who have thought to block it off with a screw? :)
mine has the fitting, so i just run a hose to my pisser.
don't really know the thread size unless i take it off and measure or you could try doing this your self.
i think that would be your best bet to match the fitting at the store!
Yamisj
Hot Dog
Yes, I did try that I took the screw to the hardware store and the smallest fitting was a 1/4" to a 1/8" nipple.
The person that had the motor before had a aftermarket pipe and they had used two big cooling lines.
Thanks though.
Yamisj
Hot Dog
Just get the 1/4 barb X 1/8p fitting then use a inline reducer connector to get to 3/16 or 1/8 line to connect to the stock pipe nipple.
Supertune--
This is a great idea, however the fitting that screws into the head needs to be 1/8th or 3/16th and the smallest one I could find was 1/4. The screw that is used as a cap on the head right now is a metric size.
Thanks
Yamisj
Hot Dog
Is your fitting pressed or screwed in?
