- australia
hey all
i currently have my cooling routed like this
is this correct? the reason i have it like that is i plan to run duel cooling when i pull the pump out and will tap it then.
anyway i ask because i had it running on the hose (the green line in the pic) and i was checking the sync on the carbs and it stalled so i reached over and turned the tap off (ski was sitting nose up. i then changed the batt terminal (unrelated issue) and went to start it again and it locked. pulled the plugs and had a look and it was full of water. so i got that out (took a while, seemed that it pulling it back in out of somewhere, exhaust?) and got it running again. should i be back flushing it from there? and are the lines oK? should the top of the head go to the top of the pipe or is it ok at the bottom?
cheers
cheers
