- Clearwater, FL
So I picked up a 96 blaster with a factory limited pipe on it the other day and I am having a problem with it and have a couple questions.
1. When I start the boat out of the water it goes from a slow idle to reving really high without me touching the throttle. I've got the idle setting backed out all the way and the idle setting screw doesn't even touch the throttle linkage with it backed out all the way so I thought I had a problem with my cable not being long enough. Well then I found out when I start it and hold down the throttle linkage it doesn't rev uncontrollably. Is there any way vibrations are causing the throttle to rev up? Please help its pretty much impossible to flush out my ski. Ironically it runs fine when in the water.
2. Do you have to take the head pipe off the exhaust manifold or can you just take off the limited chamber when removing the motor out of a blaster.
Thanks,
Dan
Thanks,
Dan
