Yes I have. I had the ski running after that., then turned the hose on, then the ski died, but having the hose nozzle quite a bit aways wasnt the best idea and didnt make it in time to turn it off. Now i have it in a small body of water in the front yard. (big jacuzzi, fresh water, no chemicals) and i got it running but it wont stay running. it seems like theres a lot of pressure inside the engine and stops the crank from turning then when i take out a spark plug it runs fine. alsi seems like theres no gas getting to the carb, like its not sucking it at all. I tihnk its time to write down my problems and take it to a mechanic.. any thoughts?
